Adding a hot water zone to a steam Oil Fired Furnace
I need to know how to add a hot water zone to an existing one zone steam boiler system. I believe the boiler is 80's model. Need specific info about how to set up the run of copper, and adding valves and such. And if you could explain the theory behind that would help me to figure it out better as well. I really need to know at what spot in the system to put the parts and what parts to get. This would make it a total of two zones for the house. I have heard of adding a water heater and doing it that way which is better? This would only be adding heat to one room.
