Laars Endurance ignitor/flame sensor failure
Hi, I recently had a Laars EBP110 Natural Gas Hydronic Boiler w/ Domestic Hot Water installed in my apt to replace an aging and leaking water boiler/heater that originally came with my apt. It worked fine for a couple of days before we lost heat and hot water. LED screen on EBP110 read LO, Locked Out, and it turns out the ignitor/flame sensor failed. We had it replaced by the installer but a week later that failed too. Am I just unlucky to have 2 ignitor/flame sensor assemblies fail within 2 weeks of each other or is the Laars unit somehow causing the ignitor/flamer sensor to fail prematurely. The installer already looked over the unit but didnt find any electrical or water problem. Any help would be greatly appreciated.
  • Slimpickins
    Slimpickins Member Posts: 359
    Bad ground
    Check your ground on your line voltage feeding the boiler. If conduit is used as a ground or you have aluminum wiring, you need to ground the boiler to a solid ground somewhere.
