Lp gas alarm
Big Will
Member Posts: 395
So there are a few Lp gas alarms available on the net. The thing is I want one with a double pole relay that can interrupt power to a solenoid in the gas line if it senses a leak. Has anyone seen this.
Re Alarm
Yes;
The system they put in in south Korea the place sensors close to the floor which were wired to a control box that actuated a valve turning the gas off. They tested it by opening a propane torch next to the sensors and watching the valve close. The system intrigued me.0 -
