Lp gas alarm
Big Will
Big Will Member Posts: 395
So there are a few Lp gas alarms available on the net. The thing is I want one with a double pole relay that can interrupt power to a solenoid in the gas line if it senses a leak. Has anyone seen this.
  • World Plumber
    World Plumber Member Posts: 389
    Re Alarm
    Yes;
        The system they put in in south Korea the place sensors close to the floor which were wired to a control box that actuated a valve turning the gas off. They tested it by opening a propane torch next to the sensors and watching the valve close. The system intrigued me.
  • Jim Hankinson
    Jim Hankinson Member Posts: 98
    LP alarm
    Check out www.smartguardtechnologies.net
