Fixing or replacing hot water radiator control valves?
Steeve
Steeve Member Posts: 3
Some questions about the control valves on my hot water radiators.  Some of the control valves turn and some don't.  First, for the valves that do turn, are they designed to shut flow all the way off?  Or just reduce the flow to a low level?  (several radiators get too warm even with the valve in the closed position).
Second, for the valves that are stuck, can they be repaired?
Third, would it be possible to replace the old valves with thermostatic valves?
All these radiators are fed by a Buderus boiler with outdoor reset and constant circulation.  The house is a 100 year old farmhouse in western Massachusetts.
Thanks!
  • Steeve
    edited December 2010
    here's another pic
    Here's another pic of one of the radiator with the control valve that I would like to replace or repair.
  • jfplumr
    jfplumr Member Posts: 13
    radiator valves
    1-Some radiator valves do in fact stop the flow altogether but some were made to allow a slight flow to prevent possible freeze damage.
    2-These radiator valves MAY be able to be repaired depending upon ther design.
    3-Yes, these valves could be replaced with non-electric thermostatic zone valves such as Honeywell Braukman.
  • jfplumr
    radiator valves
  • marcref
    marcref Member Posts: 2
    Valves - Macon
    Check out maconcontrols.com they are right in your back yard, western ma. They specialize in these types of valves.
  • marcref
    Valves - Macon
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,413
    How far west?
    Hydronicalternatives.com in Springfield carries a full line of valves also.
    cell # 413-841-6726
    Thermostatic valves
    work well if the system is piped in some sort of parallel method. If it is in series it will not work well.
    cell # 413-841-6726
