Viessman Vitoflame 100 natural gas burner D1 faults
ScottB
Member Posts: 2
Having difficulty trouble shooting a D1 fault on a Viessman Vitoflame 100 natural gas chassis burner installed on a Viessman VG2-40 Vitola Boiler, replaced grounding elecrode,ignition electrode and ionization rod. still has lock out.Replaced gas valve still no solution. checked draft and micro-amps both fall within viessman specs. anybody have any ideas as to this continuing problem boiler has been installed for 5 years with no problems until two days ago.
Which Control
Do you have on the boiler? Is it an old Trimatik?There was an error rendering this rich post.
Control type
Vitotronic 2000
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
