insulating underfloor for retrofit
Retro
Member Posts: 13
I'd like to consider underfloor radiant for a retrofit but have some concerns. First, I have some doubts whether inspector will OK reduced crawlspace clearance due to new insulation.
Would it be practical to delete some or all underfloor insulation in favor of a conditioned crawlspace?
The short answer is no.
Most of the radiant floor systems require a minimum of R-13 under the floor to drive the heat up into the desired space. Otherwise you will have ceiling radiant in the crawlspace.
www.uponor.com has some great literature on installation methods.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
