insulating underfloor for retrofit
Retro
Retro Member Posts: 13
I'd like to consider underfloor radiant for a retrofit but have some concerns. First, I have some doubts whether inspector will OK reduced crawlspace clearance due to new insulation.
Would it be practical to delete some or all underfloor insulation in favor of a conditioned crawlspace?
  • meplumber
    meplumber Member Posts: 673
    The short answer is no.
    Most of the radiant floor systems require a minimum of R-13 under the floor to drive the heat up into the desired space.  Otherwise you will have ceiling radiant in the crawlspace.
    www.uponor.com has some great literature on installation methods.
