Honeywell TRUSTEAM - 3 blinking red lights
derek23
Member Posts: 1
I have a Honeywell TruSteam humidifier and the service light just started blinking 3 times. According to the Manual that means "failure to fill water tank". Here are the things I have tried:
* hit GO button, this resets but after 5-7 mins, starts blinking again
* changed the filters in the Reverse Osmosis filtration. same thing, they started blinking again
* cleaned the unit. same thing, 3 red lights blinking
I just ordered a new Water Assembly Sensor kit thinking perhaps thats the issue. I did fill up the tank with water and then it started Humidifying but after one day, the 3 blinking lights came on. Errr. I've checked that I have water going to the unit, even had a plumber come out.
Any ideas on what it might be? Do you think it is the Water Sensor? Seems it just isnt triggering the release of water.
Any help is appreciated!! THX
When I see blinking lights....
....I call tech support . Before you spend money call them up and have an electrical meter ready ...Let them diagnose the problem ... It's the way of the new world with a mechanic ..There was an error rendering this rich post.
- 120 Geothermal
