Best vent?
Irv
Member Posts: 95
I would like to put an adjustable vent for my one pipe steam on one of the rads.
What do you fellas think about the hoff 1a?
has my vote
For an adjustible vent, I have found them to be very reliable.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Hoffman 1A
Hoffman 1A can be adjusted from .026 to .225 cfm @ 2oz. So that means it will work on a wide range of radiators. I think I heard only one complaint from a light sleeper. It has a clink/plink that woke him up all the time.
Vent Rite #1 vents at a similar rate. Is quieter for a bedroom.
Pricewise: Hoffman beats Ventrite by about 15 bucks.0 -
I prefer vent rite
actually slightly slower on high vent but they are easy to adjust and consistent. Price in my area is opposite as Hoffman are less common here.Cost is what you spend , value is what you get.
cell # 413-841-6726
best steam vent
have tried them all over the years and I now always use and recommend the Heattimer Vari-Vent.....excellent, long lasting and one of the fastest vents I've used. Find them very well priced at www.steamdepot.com0 -
where tobuy
Where would I buy vent-rite valves?
I'm on Long Island.
Thanks,0 -
They sure are hard to find.
Maybe Charlie has a better source.
http://heating-and-cooling.hardwarestore.com/97-581-air-valves/air-valve-167254.aspx0 -
I buy from my wholesalers
That is the price I sell them for. They do not seem to be popular in your region. It is an issue with manufacturer representatives and market share I am sure after many phone calls when I was in White Plains.Cost is what you spend , value is what you get.
cell # 413-841-6726
I never had to buy any
I found a few in a scrap pail when I took over this place. They were obviously pretty old, a bit banged up, numbers wore off, threads a little bare. I tried one in my troublemaker convector 7 EDR. And also in my cold room, last riser on the main, on the second floor. Ventrite tamed both of them. So I'm sold. I did a bit more geographical digging for you here are 2 more suppliers.
http://www.watertownsupply.com:88/Products/HeatSteam.html
http://www.sweeneyrogers.com/id2.html
The manufacturer of Vent-Rite #1 is Barnes & Jones, Newtonville, Mass.0
