Best vent?
Irv
Irv Member Posts: 95
I would like to put an adjustable vent for my one pipe steam on one of the rads.
What do you fellas think about the hoff 1a?
  • Dave in QCA
    Dave in QCA Member Posts: 1,804
    has my vote
    For an adjustible vent, I have found them to be very reliable.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • crash2009
    crash2009 Member Posts: 1,478
    Hoffman 1A
    Hoffman 1A can be adjusted from .026 to .225 cfm @ 2oz.  So that means it will work on a wide range of radiators.  I think I heard only one complaint from a light sleeper.  It has a clink/plink that woke him up all the time.
    Vent Rite #1 vents at a similar rate.  Is quieter for a bedroom.
    Pricewise: Hoffman beats Ventrite by about 15 bucks.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    I prefer vent rite
    actually slightly slower on high vent but they are easy to adjust and consistent. Price in my area is opposite as Hoffman are less common here.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    best steam vent
    have tried them all over the years and I now always use and recommend the Heattimer Vari-Vent.....excellent, long lasting and one of the fastest vents I've used. Find them very well priced at www.steamdepot.com
  • Irv
    where tobuy
    Where would I buy vent-rite valves?
    I'm on Long Island.
    Thanks,
  • crash2009
    They sure are hard to find.
    Maybe Charlie has a better source.
    http://heating-and-cooling.hardwarestore.com/97-581-air-valves/air-valve-167254.aspx
    I buy from my wholesalers
    That is the price I sell them for. They do not seem to be popular in your region. It is an issue with manufacturer representatives and market share I am sure after many phone calls when I was in White Plains.
    cell # 413-841-6726
  • crash2009
    I never had to buy any
    I found a few in a scrap pail when I took over this place.  They were obviously pretty old, a bit banged up, numbers wore off, threads a little bare.  I tried one in my troublemaker convector 7 EDR.  And also in my cold room, last riser on the main, on the second floor.  Ventrite tamed both of them. So I'm sold.  I did a bit more geographical digging for you here are 2 more suppliers.
    http://www.watertownsupply.com:88/Products/HeatSteam.html
    http://www.sweeneyrogers.com/id2.html
    The manufacturer of Vent-Rite #1 is Barnes & Jones, Newtonville, Mass.
