Place for main vent
acl10
acl10 Member Posts: 349
My system doesnt have any main vents. I therefore put Gorton ds and cs on the radiators and they vent well. My main on the far side makes a turn has about 2 feet of pipemakes another turn and goes into the wet return going down out of that small pipe where the main connects to the return about 2 feet of pipe there are two  risers going up to the radiators in the front rooms. Can I put a main vent on one of the risers?
  • Rod
    Rod Posts: 2,067
    Main Vent
    Yes, that should work. Can 't you put them just where the dry return drops into the wet return?
    - Rod
  • acl10
    main vent
    I am just concerned that when the condensate flows back from the radiator attached to the riser the water wont go into the vent. Is that a concern? also How do you put the vent into the pipe do you drill a hole in the pie and make threads and screw it in. Will that work or will it damage the pipe?
    I dont want to put it where the return joins the main be caise thats in a bedrroom and will make to much noise.
