Place for main vent
acl10
Member Posts: 349
My system doesnt have any main vents. I therefore put Gorton ds and cs on the radiators and they vent well. My main on the far side makes a turn has about 2 feet of pipemakes another turn and goes into the wet return going down out of that small pipe where the main connects to the return about 2 feet of pipe there are two risers going up to the radiators in the front rooms. Can I put a main vent on one of the risers?
Main Vent
Yes, that should work. Can 't you put them just where the dry return drops into the wet return?
- Rod0 -
main vent
I am just concerned that when the condensate flows back from the radiator attached to the riser the water wont go into the vent. Is that a concern? also How do you put the vent into the pipe do you drill a hole in the pie and make threads and screw it in. Will that work or will it damage the pipe?
I dont want to put it where the return joins the main be caise thats in a bedrroom and will make to much noise.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
