Peerless spark Issue on PI-80 (i.e. Munchkin)
bjwerti
Member Posts: 5
Peerless / Munchkin PI-80 Spark ProblemI have a 2003 Peerless PI-80 NG (i.e. Munckhin) boiler that has worked well for 7years. I have only replaced the spark electrode once about 3yrs ago. It recently has started to ignite poorly or not at all and another new electrode didn't help. I've checked and I have a good ground, and good source voltages (123VAC line; 27VAC transformer).Unit is pretty clean inside for 7yr old unit (see pics of condition). I took the burner off & cleaned it near the bolt areas and I put a new burner gasket on too. I noticed a small harline crack at one of the bolt holes, but it hasn't progressed into the burner at all so I assume it's not an issue of concern. If I need a new control board, is there any way to upgrade my WHA Rev 0 board to the new Munchkin 926 board? I know I can purchase the Peerless P125 upgrade kit, but that seems pretty outdated now for a control. Is the P125 a good control board, or not worth it from the WHA?
just up graded 3 199's can be done easily . Check you gas pressure .may be low coming in0 -
926 Control Upgrade on PI-80 Analog board
My current PI-80 Pinnacle has a Rev 0 WHA analog control board. When I upgrade to the 926 Control:
- Is it required to install a blocked vent pressure switch like newer units have, or are there instructions for a jumper?
- Do the supply/return thermisters require replacement when upgrading to the 926 control?
- Any other adjustments required?
Thanks.0 -
Spark Issue Solved
I upgraded my Peerless PI-80 to a Munchkin 926 control panel today, and it works perfect now. What an upgrade from the WHA analog to the 926 digital!0
- 50 Industry Classes
