Can I convert from a forced air/duct system to STEAM?
is that nuts?
I'm not a big fan of the forced air heat in our house... can I just get water coils installed into the ducts or something?
I know, this seems nuts, but as you can tell, I don't know anything about this.
thanks for your help!
    Steamhead Member Posts: 18,211
    Sure you can!
    but you'd be better off using radiators instead of duct coils.
    There are some very attractive steam radiators being made- go here:
    http://www.steamradiators.com
    Note that these are steel and should not be used in the same system as cast-iron radiators. Their thermal performance is very different. But if you're starting from scratch, this would not be a problem.
    Consulting
  • TomM
    TomM Posts: 233
    come to the darkside.
  • gerry gill
    gerry gill Member Posts: 3,083
    I did!
    and my house heats better now than it ever has..much more comfortable.
    gwgillplumbingandheating.com
    How cold
    has it been so far, Gerry?
    Consulting
  • gerry gill
    been down in the
    high 20's so far..i keep the house at 75..i know, i know, but i like it warm..
