Can I convert from a forced air/duct system to STEAM?
blamesarah
Member Posts: 2
is that nuts?
I'm not a big fan of the forced air heat in our house... can I just get water coils installed into the ducts or something?
I know, this seems nuts, but as you can tell, I don't know anything about this.
thanks for your help!
Sure you can!
but you'd be better off using radiators instead of duct coils.
There are some very attractive steam radiators being made- go here:
http://www.steamradiators.com
Note that these are steel and should not be used in the same system as cast-iron radiators. Their thermal performance is very different. But if you're starting from scratch, this would not be a problem.All Steamed Up, Inc.
Consulting0 -
come to the darkside.There was an error rendering this rich post.
I did!
and my house heats better now than it ever has..much more comfortable.gwgillplumbingandheating.com
How cold
has it been so far, Gerry?All Steamed Up, Inc.
Consulting0 -
been down in the
high 20's so far..i keep the house at 75..i know, i know, but i like it warm..gwgillplumbingandheating.com
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
