PRESSURE TANK
bheat
Member Posts: 1
I have an old Penco gas boiler with a #24 Thrush pressure tank and vacuum breaker. The pressure tank has split a seam and is leaking, I need to find a new one In Cincinnati Oh. area. Who should I be looking for, and what other info do I need to get the correct tank for this boiler. I have another problem that started a year or so ago, when the boiler fires, I get a small leak from the drip leg. I replaced the pressure valve, regulating the incoming fresh water, however this did not help. Until now, I had no complaints, so I let it drip. Now I have complaints about a 2nd floor apartment that has to bleed their radiators or they get no heat.
Any ideas will be helpful
Thanks
bheat
Thanks
bheat
The tank was water logged
That is why the pressure relief valve was dripping. Find a heating pro in the search feature find a pro and have a nice new extrol tank installed that is sized to your system.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
