PRESSURE TANK
bheat
bheat Member Posts: 1
I have an old Penco gas boiler with a #24 Thrush pressure tank and vacuum breaker.   The pressure tank has split a seam and is leaking, I need to find a new one In Cincinnati Oh. area.  Who should I be looking for, and what other info do I need to get the correct tank for this boiler.  I have another problem that started a year or so ago, when the boiler fires, I get a small leak from the drip leg.  I replaced the pressure valve, regulating the incoming fresh water, however this did not help.  Until now, I had no complaints, so I let it drip.  Now I have complaints about a 2nd floor apartment that has to bleed their radiators or they get no heat.
Any ideas will be helpful
bheat
