Cast Iron Steam Radiator Vents....Varivalve.
Athana
Athana Member Posts: 105
In past house had used Maid o mist vents with interchangeable screw on caps..but I have come across an item that looks of high quality but unconventional.... VARIVALVE by Heat-Timer Corp in Fairfield NJ.
It has a sliding variable thing on side.
Has anyone used them and will they out perform Maid O Mist?
This sliding feature would be great to adjust each radiator some what.
Thanks
  • They are supposed tobe good vents.....
    many of the top pros use them.  However, I believe they vent waaay too fast.   This can cause uneven heating, banging radiators and other problems.  I recommend large main vents, with small radiator vents, like the Hofman 1A adjustable or Ventrite adjustable.
  • Redcat
    Redcat Member Posts: 1
    Cast Iron Staem Radiator Vents... varivalve
    I have used varivalve vents on large steam radiators and found that they work very well. I can't say that they are any better than Maid of Mist #D unless you need to make a lot of adjustments. They certainly cost a lot more.
