wiring diagram
eveready
eveready Member Posts: 4
I need a wiring diagram for a L6010A aquastat
  • HDE
    HDE Member Posts: 225
    I don't believe Honeywell ever had a L6010 series
  • Ironman
    Ironman Member Posts: 7,730
    edited November 2010
    An Oldie but a Goodie
    That one's as old (maybe older) as I am.  I miss the old crinkle paint job.
    See if the attachment helps.
    Bob Boan
  • icesailor
    icesailor Member Posts: 7,260
    Control:
    HDE,
    That is the Honeywell "6000" series. Like the 6006 Aquastats.
    My question is to the one that needs the info. But if it is bad, they have a digital control and I can never remember what the # is, but it will do everything that any control that you need will do and it gives you a digital read out on what it is doing and what the temperature is that it is checking. You can set it up to replace any control. From one that is a cold start boiler to one that is warm start but not controlling a circulator. I use it for most replacements. It costs more though. But that one control replaces a bunch of others so it will cut down on inventory.
    And it is easy to figure out if you are replacing that old one.
  • billtwocase
    billtwocase Member Posts: 2,384
    good control
    still have them in the field and on the shelf
