special radiator valve
FGS
FGS Member Posts: 1
I need to replace a special radiator valve which no one local has ever seen.
It is on a conversion system (steam to hot water)
There are two 3/4" BI pipies coming up through the floor that connect to each side of the valve.
On the bull side of the valve there is a single connection to the radiator.
The valve handle is on top.
  • Steve_210
    Steve_210 Member Posts: 650
    pictures
    can you post a picture
  • icesailor
    icesailor Member Posts: 7,260
    Special Valve:
    I know what you have and I doubt seriously you will find a similar replacement valve.
    If and when you replace this valve with two valves and a major re-pipe of the connection, Dan H. might like it as a conversation piece at his seminars.
    "What is this and what is it used for?"
    "What the FFFFFF?"  "I just duuuuunnnn'o,"
  • bob_46
    bob_46 Member Posts: 813
    Valve
    Sounds like a Honeywell "Unique" . Good Luck
  • icesailor
    Special Valve:
    Here is some info on them:
    http://www.renovators.com/forum/topic_show.pl?tid=127
    I would say that it depends on where they are leaking as to the possibility of repairing it.
    Steamhead Member Posts: 18,184
    It's not a conversion
    That sounds like a Honeywell "Unique" hot-water valve, or a similar model. It would probably be easier to repair it than to try finding a replacement.
    Consulting
