special radiator valve
FGS
Member Posts: 1
I need to replace a special radiator valve which no one local has ever seen.
It is on a conversion system (steam to hot water)
There are two 3/4" BI pipies coming up through the floor that connect to each side of the valve.
On the bull side of the valve there is a single connection to the radiator.
The valve handle is on top.
pictures
can you post a picture0 -
Special Valve:
I know what you have and I doubt seriously you will find a similar replacement valve.
If and when you replace this valve with two valves and a major re-pipe of the connection, Dan H. might like it as a conversation piece at his seminars.
"What is this and what is it used for?"
"What the FFFFFF?" "I just duuuuunnnn'o,"0 -
Valve
Sounds like a Honeywell "Unique" . Good LuckThere was an error rendering this rich post.
Special Valve:
Here is some info on them:
http://www.renovators.com/forum/topic_show.pl?tid=127
I would say that it depends on where they are leaking as to the possibility of repairing it.0 -
It's not a conversion
That sounds like a Honeywell "Unique" hot-water valve, or a similar model. It would probably be easier to repair it than to try finding a replacement.All Steamed Up, Inc.
Consulting0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
