Insulating a boiler
Kev82
Member Posts: 4
I have a coal/steam furnace converted to oil/steam. I would like to insulate it. What should I use?
I used kaowool ceramic insulation.
T should be available at a good insulation supply house. See my NEW system pics below in my signature.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
duplicate post
delete post1-pipe Homeowner - Queens, NYC
buy location
Where can i buy kaowool?0 -
I have had R5.4 foam board with the metal foil covering
on my uninsulated tankless (of 1939 boiler) for 20 years. Also, on the top of the boiler as an attempt to enhance inside "insulation." Tech's have never raised their eyebrows. It looks fine and really reduces outside temp of tankless. Might be the way to go at least on flat surfaces. I tied wrap mine. Don't know if using an epoxy would be appropriate.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
