Burnham boiler conversion to natural gas
langer
Member Posts: 1
<span style="font-size:12pt">I have a 2006 Burnham boiler 205pil-gei2 series 2 model B. it runs on LP gas and I want to convert it to natural gas. Burnham has a kit that I can order through a local supplier that is costly. Any other options that maybe won’t cost so much? Is there an internet supply house that I could order from?</span>
<span style="font-size:12pt">Thanks</span>
The answer is a big NO
get the kit from Burnham and know that you have everything you need to do the job right.
Next have you ever done this before? If not hire a professional who knows what they are doing. Make sure you insist on having a combustion analysis done when the conversion is completed.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
