Digital Water Temperature control
Big Ed_4
Member Posts: 3,364
I am looking for a simple remote digital water temperature control with at least one dry contact ... I thought it would be easy but I had been on the phone and in supply houses with no luck ..
I am installing a heat exchanger for a small indoor pool ... I would like to use a nice looking wall mounted digital control in the pool room which has a probe to submerge into a well of the supplying pool water . with one set of contact to control the circulator on the boiler ... You would think it would be easy ... stopped by a large pool supply house today ... They can only supply me with a total pool electronic package , which is not needed and for big bucks .. The electronics controlling the small electric heater has no extra contact to interface talking to the manufacture .. So a flow switch and a separate thermostat is the way to go .. Help
Temp control
What about a low temp aquastat??0 -
Setpoint control
I use the Tekmar 150 setpoint control for this application.0 -
If you don't like the ETC option you can get one of these at an alarm supply house and add a 110V relay for the circ:
http://www.winland.com/products/EA200/EA200.htm0
