Digital Water Temperature control
Big Ed_4
Big Ed_4 Member Posts: 3,578
I am looking for a simple remote digital water temperature control with at least one dry contact ... I thought it would be easy but I had been on the phone and in supply houses with no luck ..
I am installing a heat exchanger for a small indoor pool ... I would like to use a nice looking wall mounted digital control in the pool room which has a probe to submerge into a well of the supplying pool water . with one set of contact to control the circulator on the boiler ... You would think it would be easy ... stopped by a large pool supply house today ... They can only supply me with a total pool electronic package , which is not needed and for big bucks .. The electronics controlling the small electric heater has no extra contact to interface talking to the manufacture .. So a flow switch and a separate thermostat is the way to go .. Help
