Low Loss Header for Small System
Brad White
Member Posts: 2,399
So I was looking for a low loss header for a small hydronic system I recently designed. This one is not the largest Taco makes, but a 6" #5900 'Flex Balance Plus' certainly makes a statement.
This system is an elementary school served by three DeDietrich oil-fired eutectic cast iron boilers moving about 460 gpm out to the system. I specified a pair of Taco's larger "007's" too. Those will be installed soon.
The second photo is a Taco KS for a different project, serving a chilled water plant for another school. The variable frequency drives behind them have their own zip code.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
Pumps
That would be a tough one to change on a Saturday night. " Gee, I think I have one of those on the truck".
Nice work,
Scott0
- 120 Geothermal
