Pressuretrol settings?
ez011
Member Posts: 4
I have a Burnham IN5PVNI-M2 that is less than two years old on a one pipe system and am not sure if the pressure it set properly. The pressuretrol says the Differential is set to 1.5psi and the Main is set to 5psi. Is this okay or would you recommend any changes?
the majority of us steamers ...
prefer to set p-trols at 0.5 outside scale and white interior dial to 1 .. there are a variety of reasons for this .. but for that you'll have to read a great many other threads ..1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
