Pressuretrol settings?
ez011
ez011 Member Posts: 4
I have a Burnham IN5PVNI-M2 that is less than two years old on a one pipe system and am not sure if the pressure it set properly. The pressuretrol says the Differential is set to 1.5psi and the Main is set to 5psi. Is this okay or would you recommend any changes?
