hydronic modelling for buffer tanks
NRT_Rob
NRT_Rob Member Posts: 1,013
anyone seen anything that can model buffer tank and temperature rises going in/out with a given heat source and load, over time, for a variety of piping configurations/flow rates?
Hydronics design studio doesn't let me change the piping, and it doesn't spec flow so I'm not very trusting of its results.
Rob Brown
in beautiful Rockport Maine.
    hot_rod Member Posts: 26,638
    did you see the one
    at the Boiler Buddy site?
    Siggy has the long hand formula in several of the PMmag articles "Buffer Up" Nov 1998
    hr
  • NRT_Rob
    not on BTU storage
    got that covered. I am interested in speed of temperature rise if you, say, pull out of the bottom instead of the top, in a 2 pipe or a 4 pipe configuration.
    there is more to that, given stratification, then just BTUs... but it's complicated.
    Rob Brown
