Help with Luxpro PSP722E Thermostat
Edfiero
Edfiero Member Posts: 2
I have a single stage heat pump and propane backup/aux heat.
1. Should I set the Luxpro 722 to be 1 stage or 2 stages of heat.
2. How do I control the point at which the Aux Propane comes on?  The Swing setting looks like it MIGHT do this although it specifically says it controls multiple stages of heat/cool.  Since my heatpump is single stage, I don't know if the AUX heat is considered a 2nd stage.  Or is there another way to control how much temp variation there is in the room temp and the set point before the AUX comes on?
Thanks
  • Big Ed_4
    Big Ed_4 Member Posts: 3,350
    Tech Support
    Your best bet is call Lux tech support .... They can walk you through it .. Easy call
  • Edfiero
    anyone out there?
    Anyone else have any suggestions?  This seems like a popular stat, surely someone has worked with it before.   The CONTACT page on the Lux website is not working.
