Heat Loss Program
Ironman
Member Posts: 7,714
Any of you guys know of a simple and cheap heat loss program that I could recommend to a home owner who wants to do their own calc.? Their house is so cut up that it would literally take may a day to measure up everything and another day to run all the numbers. I'm swamped right now and don't have that kind of time.
Preferably a program that you plug the numbers into instead of trying to draw the layout with a mouse like Wrightsoft does.
Thanks
Thanks
Bob Boan
Heat Loss Program
Hi- You might want to take a look at this program. http://www.hvaccomputer.com/
Very easy to use. The Residential version for commercial use is about $400 but they have the same version available for the homeowner at $ 49 which is useable for 2 months. There is a trial version you can download to check out the features.
- Rod0 -
Slant Fin Heat Loss
Heat loss explorer by Slant fin is still around but you may have to search for it0 -
Heat Loss
Try Siggy's Heat Load Pro, very good program,I just got it a couple of weeks ago, well worth the money, it also has a Heating Cost Estimator along with it, check out John Siegenthaler's web site, www.hydronicpros.com0 -
I have the free version of this that comes with his book. It is enough to tease me and to convince me that if I were to do this kind of thing on a regular basis (I am not a professional, so I could not quite justify the cost), I would want the commercial (professional?) version of the software. The free version handles only two rooms on each of two zones, and you cannot save your work. It gives you a good idea of what the software can do, though.
I think the book alone is well worth the money, so for me, the educational version is free.0 -
a form or Excel sheet
can be found here. If you want a hand calc sheet. Thanks to the Pikes Peak, Colorado Building Dept
www.pprbd.org/plancheck/heat_loss.htmlBob "hot rod" Rohr
heat loss
Try WarmBoard thru Rehau, Radwiz thru Vega, Burnham and Taco offer it as well, all free.... You do have to draw pictures w/ Taco FlowPro.0 -
Heat Loss Programs:
The Slant Fin program is great. I've used it for years. I'm sorry it isn't available anymore.
I used the IBR/Hydronics Institute system for years and years and always wanted to find a program that was based on IBR. Every one I tried was for AC or warm air. The S/F program is actually the IBR method. I have it on my laptop and I can go through a house quickly. I've never found anything as easy to use.
But, that's me.0 -
i posted links to...
both Taco FloPro and SlantFin Heatloss Explorer here:
http://www.heatinghelp.com/forum-thread/131667/Help
the SlantFin program is still available .. personally, I prefer Taco's FloPro1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
