how to prime a two pipe system?
poppop
Member Posts: 7
My oil burner in my shop has no oil going to the system. how do I prime the system. There is oil in the tank. Thanks
absolutely
Slo is absolutely correct. Most people think that they are out of oil, and reset until sun up. If the filters are clean, by-pass plug installed, no air leaks, no valves on the return, it should pick up prime, unless the pump is gone due to no lubrication. Take the nozzle line off 1 end, and stick it in a can to see if it does have oil at the pump. If so, then you have other problems0
- 50 Industry Classes
