how to prime a two pipe system?
My oil burner in my shop has no oil going to the system. how do I prime the system. There is oil in the tank. Thanks
  • billtwocase
    billtwocase Posts: 2,384
    absolutely
    Slo is absolutely correct. Most people think that they are out of oil, and reset until sun up. If the filters are clean, by-pass plug installed, no air leaks, no valves on the return, it should pick up prime, unless the pump is gone due to no lubrication. Take the nozzle line off 1 end, and stick it in a can to see if it does have oil at the pump. If so, then you have other problems
