steam pressure
Joeyjr
Joeyjr Member Posts: 11
What is the best way to slow steam down when I only have 11/2 supplies?
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Turn off the boiler....
    But then, I don't think that is really what you're asking.
    Can you elaborate a little bit.  What is the problem?  Describe your system, pictures always help.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • crash2009
    crash2009 Member Posts: 1,478
    1.5" supply valves?
    Too much pressure?  Is the steam coming out of the boiler or the radiator?
  • Joeyjr
    Too much pressure
    I'm going to be replacing the existing boiler so when I do I'm trying to get the boiler to stay running longer and not bounce on and off due to pressure. Is down firing the boiler an option? It's only a little 3 section residential.
  • Dave in QCA
    Properly sized boiler would help
    You need to purchase a boiler that is matched to your load.  Do you have cast iron radiators?  They are measured in sq ft of radation.   A steam boiler also shows the sq ft of steam radiation that it will accomodate.  If they are properly matched, the short cycling that you describe should go away.
  • haaljo
    haaljo Member Posts: 112
    Shoud be easy to reduce pressure
    1) Do you have a  gauge (3#) on your pipe? The one on the boiler doesn't count.
    2) Do you know what a pressuretrol is?
    Sometimes the pressuretrol is not operating for a number of reasons. Read up on this stuff including Dan's books. "You got Steam" is a great first read.
