Hot water
Rock
Rock Member Posts: 50
I have a Peerless oil fired boiler with a coil for hot water. The water does not get hot . It only gets hot when the thermostat for thwe heat is turned up. What controlls the hot water ?
Paul
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Depends
    Depends on the control used .... My guess from what you are telling me is that you may have a triple aquastat ... Is there a relay inside that turns on the circulator ? Then it would be the low side... Your problem may be your hot water coil is dirty too ..
