Fins for a steam pipe
acl10
Member Posts: 349
Can I put fins on the main steam pipe in the basement to generate more heat? If yes where can I get them?
Insulate the Steam Pipes!
You don't want to do that! The job of the steam mains is to take steam to the radiators in the house, not be a radiator itself. What you want to do is insulate the steam mains very well so they won't act as a radiator. Here's an article by Dan on the importance of insulation
http://www.heatinghelp.com/article/11/Hot-Tech-Tips/300/Why-you-should-insulate-steam-pipes
- Rod0 -
If you want heat for the basement
you can install iron fin tube element if it is an unfinished space. The best way is to install a hot water baseboard loop with related plumbing so you can control the temp you want. and insulate you mains so the steam works faster and quieter.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
