What is the best boiler for me
acl10
acl10 Member Posts: 349
I am thinking ahead in case I change my boiler. I would like to know what the professional recommend here. make, model size, easiest to install,efficient, reliable, easy to get replacement parts etc.
I have 12 radiators of which 2 are small bathroom radiators in a two story house with a basement. The basement is heated by a circulator closed loop system which runs through the same boiler. Therefore the boiler would have to have a cutout for it. I was wondering whether it would be better to run it from a water heater or is it more efficient to run the circulator from the boiler.
I would like the boiler to have enough cutouts to install 2 LWCO and other parts I would need.
Thanks for commenting
  • Rod
    Rod Posts: 2,067
    edited November 2010
    Yoiu need to do your Homework
    Hi- You're sorting of asking the question,"How high is up?"  The answers you want we can't give you without knowing a lot more about your steam system. Do you have Dan's books on steam heating? If you don't, I'd start with them.
    http://www.heatinghelp.com/products/Super-Deals/14/129/A-Steamy-Deal
    as they tell you how to go about replacing a steam system.
    There is also a lot of information on this site in the Resources section above, Here is a link that might be of help to you. http://www.heatinghelp.com/article/11/Hot-Tech-Tips/186/How-to-replace-an-old-steam-heating-boiler
    - Rod
    Steamhead Member Posts: 18,205
    And
    are you looking at oil or gas?
    Consulting
  • acl10
    Gas
    Gas
  • Rod
    Rod Posts: 2,067
    For Gas - WetBased Power Burner
    Hi- If you are using gas, the type of boiler that is considered most efficient is a wetbased one with a power burner. Steamhead does a lot of these as does Charlie from wmass. I would find one of their posts and click on their name and read the past posts they have written. You should be able to find some discussion and pictures of wetbased boilers they've installed.. They mainly use either SlantFin or Smith. You might also want to read the latest posts of jpf321 as he is in the process of installing a wet based Slantfin with a gas power burner and has kindly shared pictures of this installation with us.
    - Rod
