Radiant under an EDPM roof
steveg
Member Posts: 16
I am looking at a radiant job from a customer on an EDPM roof. It is for snow melt on the service walkway.
The following is their question:
<span style="font-size:12pt">The roof is plywood, then a pitched foam board and then they wanted the radiant. Is there something recommended over the radiant before they lay the rubber roof?</span>
check with the tubing manufacturer
Check with the tubing manufacturer Steve. There may be some concerns with providing a barrier between the petroleum based roof material and the tubing. That is all the info I have for you sorry.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
