Radiant under an EDPM roof
steveg
Member Posts: 16
I am looking at a radiant job from a customer on an EDPM roof. It is for snow melt on the service walkway.
The following is their question:
<span style="font-size:12pt">The roof is plywood, then a pitched foam board and then they wanted the radiant. Is there something recommended over the radiant before they lay the rubber roof?</span>
check with the tubing manufacturer
Check with the tubing manufacturer Steve. There may be some concerns with providing a barrier between the petroleum based roof material and the tubing. That is all the info I have for you sorry.0
