light popping noise
JD_5
Member Posts: 5
My boiler is making rapid light popping noise under fire, is it lime deposits? C.DeWitt
Confusing to see that "I posted this"
Confusing to see that "I posted this", when I did not. How did both of us get the same screen name?0 -
happened before
This has happened before. I know I'm no longer the only Brian on the Wall. As I recall, Dan noted that the system does not check for duplicates and encouraged everyone to use his/her full name.There was an error rendering this rich post.
OK.
I changed my screen name from JD to JDB. I hope that is enough to make it unique.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
