light popping noise
JD_5
Member Posts: 5
My boiler is making rapid light popping noise under fire, is it lime deposits? C.DeWitt
Confusing to see that "I posted this"
Confusing to see that "I posted this", when I did not. How did both of us get the same screen name?0 -
happened before
This has happened before. I know I'm no longer the only Brian on the Wall. As I recall, Dan noted that the system does not check for duplicates and encouraged everyone to use his/her full name.There was an error rendering this rich post.
OK.
I changed my screen name from JD to JDB. I hope that is enough to make it unique.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
