light popping noise
JD_5
JD_5 Member Posts: 5
My boiler is making rapid light popping noise under fire, is it lime deposits? C.DeWitt
  • Jean-David Beyer
    Confusing to see that "I posted this"
    Confusing to see that "I posted this", when I did not. How did both of us get the same screen name?
  • Brian_74
    Brian_74 Member Posts: 237
    happened before
    This has happened before. I know I'm no longer the only Brian on the Wall. As I recall, Dan noted that the system does not check for duplicates and encouraged everyone to use his/her full name.
  • Jean-David Beyer
    OK.
    I changed my screen name from JD to JDB. I hope that is enough to make it unique.
