Pressuretrol/Gauge Manifold
crash2009
crash2009 Member Posts: 1,478
I just did a dry fit and thought I should get some critique from you guys prior to installing on the boiler.  Any obvious problem with my design?  Any pointers on actual assembly?  All I know about pipe fitting is "dont strip the threads", and "dope-teflon-dope".  The first picture is how it is now, and the second is awaiting your approval.  In case you were wondering the old pressuretrol will be mounted at the top of the cross.  If the picture doesn't show good, below the gauge thats a snubber and a valve.  Also I don't want to win the ugly contest with this.
  • LarryC
    LarryC Member Posts: 330
    Why not a Vapor stat?
    What pressures are your system running?
  • crash2009
    Vaporstat is
    going on eventually.  I have some other priorities first.  This gauge stopped working recently. This manifold is just to get the gauges up and isolated.  You think my design will work OK?
