Pressuretrol/Gauge Manifold
crash2009
Member Posts: 1,478
I just did a dry fit and thought I should get some critique from you guys prior to installing on the boiler. Any obvious problem with my design? Any pointers on actual assembly? All I know about pipe fitting is "dont strip the threads", and "dope-teflon-dope". The first picture is how it is now, and the second is awaiting your approval. In case you were wondering the old pressuretrol will be mounted at the top of the cross. If the picture doesn't show good, below the gauge thats a snubber and a valve. Also I don't want to win the ugly contest with this.
Why not a Vapor stat?
What pressures are your system running?0 -
Vaporstat is
going on eventually. I have some other priorities first. This gauge stopped working recently. This manifold is just to get the gauges up and isolated. You think my design will work OK?0
- 120 Geothermal
- 394 Solar
