One Pipe Steam - Dropped header
J.R. Madden
Member Posts: 10
When building a dropped header does the bottom of the dropped header become dimension "A" ??
Dimension A does not change
Dimension A is 28" measured from the water line.
The piping configuration coming out of the boiler does not change that.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 169 Indoor-Air Quality
- 50 Industry Classes
