One Pipe Steam - Dropped header
J.R. Madden
When building a dropped header does the bottom of the dropped header become dimension "A" ??
Dimension A does not change
Dimension A is 28" measured from the water line.
The piping configuration coming out of the boiler does not change that.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
