Quick Air Vent Question
Sil
Sil Member Posts: 71
Trying to learn all I can about my single pipe steam system. After 12 years of service I decided to refinish my rads and have had all sorts of surging and pipe banging issues (no good deed goes unpunished).
Today I decided to hunt around for a main vent. Several years ago I insulated all the pipes around the boiler and there were no vents in the piping around the boiler. I tried my best to follow the main line into the finished part of my basement and behind a wall.
Lo and behold in a really tight area behind the wall where the main has an elbow where the return must start its run... I could feel a vent. I had to rip out part of a window well... but I got the valve off (pictured below). Its an old Hoffman No 70 and had only 1/8" threads.
My question is, what should I replace it with?
Can I for the time being (like until the weekend) just put a Maid-O-Mist on there with the little cap taken off (the screw on cap that would make it a #4, 5 or 6)?
Thx
<img src="http://i203.photobucket.com/albums/aa262/silmarg/DSC_0117.jpg" width="1023" height="680" alt="" />
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    really small
    try as soon as possible to put on a proper main-line vent, like a gorton#2. that hoffman is only capacious enough for a radiator-not a main!--nbc
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Main Vent
    Is there a bushing where you removed this 1/8" vent?  If so, take it out and follow Nicholas' advice.  If it is not a bushed fitting, then you have another problem.  It really should be replumbed so that you can install a proper "main" vent.  However, in the meantime, you could use a Heat timer varivalve vent in the wide open position. It will vent the same as a Hoffman #75.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Sil
    no bushing
    The vent was tapped into the elbow at the end of the main (where it turns down into the return).  No Bushing.  Just and 1/8" tapping.
    I will have to find a heat-timer dealer in my area.
    Ugh... I keep finding more bad news...
  • Dave in QCA
    try pex supply
    Try Pex Supply
    http://www.pexsupply.com/Varivalves-362000
    Make sure you get the angle style, as this is the configuration of the one you removed.
