Sight Glass / Water Level Question
sweetlou
Member Posts: 22
1)I was messing with the site glass valves and not it is leaking a little steam. Should the top and bottom valve both be all the way open (the ones directly above and below the sight glass)?
2)I went to flush the boiler with the lowest valve (with hose attached) and nothing came out. I was pretty surprised. Why didn't any water come out?
well good time of year to find issues
#1 both valves full open hen a bit closed I usually go 1/8 turn. The stuffing box on the stem may need tightened.
#2 sludge has it plugged. I use a heavy cable tie or a piece of copper wire and push it into the valve with it open and a bucket under the valve. Be prepared for that valve to not close all the way once you get it to flow. They make caps for hose threads make sure you have a washer for in the cap.Cost is what you spend , value is what you get.
cell # 413-841-6726
Sludge Removal
Thanks Charlie from WMAss. I am having difficulty getting anything in the pipe in order to drain the sludge.The pipe has a bend which makes it difficult to get anything in there to get the sludge moving.0 -
That's why
you use a cable tie or a length of soft copper wire (try about 10 or 12 gauge solid)... they both should be flexible enough to get in there, unless the thing is not just plugged with sludge, but is caked on.Br. Jamie, osb
Plumber visit today
I had a plumber out today and he wouldn't even attempt to unclog it. He said he would have to take apart the boiler in order to drain it (at a cost of $450). He said the boiler should be drained weekly...in addition blowing out
the low water cut off.
Then he said I needed a new sight glass..there were small chips at the ends of the sight glass (cost $268).
I was sort of shocked at the costs and told him I had to think about it. What do you think?0 -
expensive repairs
i suspect you have the wrong man for the job. the boiler should not be unnecessarily drained-only flushed!
of course, when the sight-glass tube is cut, there are naturally a few dings, which are no problem. for myself doing the job, one hour is enough to take out the tube, scrub it with my mini bottle brush, and put it back on with new washers. during this time, as the boiler is off anyway, i can flush the boiler out through its drain, and then flush the returns, which may not be emptying all the water, but just enough to wash out the calcium.
i prefer the arrangement with the steam pro to be charged on an hourly basis.
there is no reason you could not learn easily to do these operations yourself!--nbc0 -
Pictures?
Hi- I tend to agree with NBC about him being the wrong man for the job. I normally drain my boiler twice a year, at the beginning of the heating system and again at the end of the heating season. The LWCO should be done weekly or possibly more frequently if the boiler water is very dirty.
Perhaps if you could post some pictures of the pipes going into the bottom of your boiler we might be able to make a better recommendation as to how you might unplug it.
- Rod0 -
Boiler Drain
I forgot to add that he said I would need a new boiler drain if he drained the boiler. The cost would be $232.0 -
Get daring.
Get a couple of buckets ready and spin out the whole boiler drain. The boiler should hold less than 10 gallons or so.0 -
boiler drain
I suggested the same thing JStar and he said it could really mess up things up inside.0 -
Costs
We don't usually discuss cost in this forum but to me, the costs this
person is quoting indicates he really doesn't want the job. If he does
get the job, he padded enough into it to ensure he has covered all the
bases.
I suggest you get a qualified steam guy in to look at things and ask him if you can observe so you can learn what to do for normal maintenance.
I had to replace my sight glass and gaskets last year and cost me about the cost of a 12 pack of Sierra Nevada's Pale Ale for the parts; I installed the parts myself in about 10 minutes and most of that was spent scraping what was left of the old gasket out of the bonnet nuts. Many years ago the tech replaced the glass and gaskets as part of the annual cleanout and the additional cost was pretty small. I usually tell the guy doing the annual cleanout to let me know if anything additional has to be done because he's already there and it saves the cost of another service call.
3PSI gauge0 -
how it might mess things up
If I had to take a guess, I would say that the plumber is worried about the nipple between the elbow and the boiler. If the boiler end is rusted in and the elbow end breaks, I imagine (I'm not a plumber) that would be a mess to try to fix.
If you're going to remove the spicket (it's not the right kind for this job anyway), you might want to let some penetrating oil work its magic over night.There was an error rendering this rich post.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
