looking for a good steam contractor
Any "steam heat pro's" that service northwest New Jersey?  I am looking for someone to come to Belvidere NJ.  I have a one-pipe system that needs some pipe run for a relocated radiator and a new radiator.  The two radiators were taken off the system before I purchased the house and I would like to add them back in.  I am having trouble locating someone to do the work who is really good with steam.  The guys who are local are the same ones who had the system set at almost 3 psi when i moved in!  I just want someone who is experienced with steam to work on the system.  Any help would be appreciated!  Thanks.
  • crash2009
    crash2009 Member Posts: 1,478
    Look in the Find a contractor area
    right here on the website.  Just enter your zip and give yourself a couple hundred mile radius.
  • adamdivine
    adamdivine Member Posts: 8
    using the search tool
    are the contractors that are found by using the search tool vetted in any way?  I guess I just want to make sure that the company I would be calling is really an "expert" when it comes to steam radiators.  I was also trying to see if anyone who might be in my general area had any recommendations.  Thanks.
  • crash2009
    I don't know
    if they are vetted. Likely someone will contact you through this discussion.
  • adamdivine
    Thanks
    I will wait for further responses
  • crash2009
    What is your zip?
    I'll type it in there myself and see if I recognise anybody.
  • adamdivine
    zip
    is 07823
  • crash2009
    I didn't recognise any of the names.
    I guess everyone is out there working.  Someone will contact you eventually.
    Steamhead Member Posts: 18,570
    Is this the area
    known as the Jersey Skylands?
    We've gone there for steam, if you can't find anyone local.
    http://www.heatinghelp.com/forum-thread/131004/ARCO-Model-K-system-in-the-Jersey-Skylands
    Consulting
  • adamdivine
    yes
    This is in the same area. I called and left a message for you.
    Got it
    we're working on a boiler replacement today and didn't get your message until late. I'll try to call tomorrow.
    Consulting
